Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1999 Daewoo Leganza 102202 miles
My engine won't start. I had the battery checked and the connections cleaned. After having the battery charged, the car ran okay but today it won't start again. I was told that the battery and the alternator are working properly. Anything else I should look at?
something must be draining the battery .. a light left on/radio left on/boot light stuck on/glove box light etc. etc. you need to find out what it is ??
If you find nothing staying on, as per instructed by Dave H. , then it may be your starter or ignition switch. What happens when you turn the key over to start the engine? Does it just click, or does the engine try to crank over? If it does just click, will any lights, radio, etc.. come on?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
