Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1992 Ford Escort Car Wo...
Auto Repair1999 Ford Ranger Lady N...
Auto Repair1988 Oldsmobile 98 Igni...
Auto Repair2001 Kia Optima Engine ...
Auto Repair2002 Dodge Intrepid Lef...
Auto Repair1999 Ford Explorer
Auto Repair2001 Kia Optima Gas Tank
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Daewoo Leganza Just doesn't stop good
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 06, 2008 4:18 pm
By YoBobYO, Have Donated
Give Feedback | Votes: 0
Brakes problem
1999 Daewoo Leganza 4 cyl Front Wheel Drive Automatic 90,000 miles
I've replaced the shoes and turned the rotors, bled the brakes. The only thing was I might of let the master run low on fluid. But I've filled it, and bled all the old fluid out. As of now, I might have 30% to 40% of the brake power this car once had. I don't want to keep replacing parts. I've also replaced the master, and booster with no change. The pedal is soft but doesn't go to the floor. In the manual, it states something about if the ABS system were to get an air bubble you have to have the dealer bleed the air out with there ABS scanner. Is this true? or is there another way to do it.
Find a car repair manual for your Daewoo Leganza Repair Question.
Posted at Tue Oct 07, 2008 2:25 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9 (635) Give Feedback | Votes: 51
ABS & TRACTION CONTROL -1999 Daewoo Leganza SX
Page 1 of 1
NOTE: Replacement modulators are shipped already filled and bled. In normal procedures requiring removal of modulator, such as to replace EBCM, air will not enter modulator, and normal bleeding will be all that is needed. If air enters hydraulic modulator, or if an unfilled modulator is installed, use brake bleeding program in scan tool to bleed modulator. Manual bleeding of hydraulic modulator is not possible. In your case if the master ran dry while bleeding, the scantool is needed to bleed it!
BLEEDING BRAKE SYSTEM
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
10/7/2008
Posted at Tue Oct 07, 2008 8:28 pm
I understand what the manual said. I read it too. I was hoping to find out if there was any other way to bleed these brakes with out it. Or tell me just what does the scan tool does to bleed the brakes?? I don't understand how this tool bleeds the brakes.
Thanks for the answer to the first question. I'd give another 5.00 for the anwser to these question.
Thanks Robert
Posted at Wed Oct 08, 2008 10:55 am
The tool commands the unit to open pathways inside to allow bleeding, and I havent heard of any way to bleed them without doing this.
Posted at Wed Oct 08, 2008 11:18 am
Thanks for the info, and I would like to give another 5.00. But first, being that this is the first time doing this. How does the point system work??? and if I give another 5,, does it go to you for answering the question??
Let me know,, and I'll get that out to you..
Thanks again for the help.
Robert
Posted at Wed Oct 08, 2008 11:28 am
Give points by clicking the feedback link next to my name, some money goes to me and some to the owners of the shop, a fair arrangement, I apprciate your sentiment! Give a vote the same way! Or click here for feedback. http://www.2carpros.com/forum/reputation.php?a=add&u=62217&p=363848&c=5c4f7163
And votes here.
http://www.2carpros.com/forum/reputation.php?a=stats&u=62217
Posted at Sun Oct 19, 2008 6:15 am
When installing the brake pads. Does the pad with the sqweeler, go in front (outside) or to the back? (inside) It seems to fit both ways. I've alway put them to the front. but I thought I would ask and make sure.
and again,, how do you rate someone.. as far as points? and what it the scale you use??? Let me know,,, Thank you,,
Robert
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
