Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 45000 miles
Lo horn suddenly stopped working and I haven't found the location of the horn yet. Where is it? Can this be a computer gliche or just a bad horn?
Thanks
Find a car repair manual for your Chrysler Concorde Repair Question.
Posted at Sun Apr 27, 2008 7:14 am
By
merlin2021,Certified 2CarPros Master Technician
Horns are usually up front near the radiator, unplg the connector, use a test light and have someone hit the horn, does the light, light? If yes the horn is NG, if not trace the wires back to the relay...Does the other horn work?
Thanks for the quick reply and here is the story as it unfolds; Hi horn works fine. Searched front end near and around radiator and can't even find access to the interior (would have to remove shroud and upper radiator support. Climbed undeneath and can't find any access beneath. Now I'm wondering if the horns are inside the wheel panel, like the battery is. Last resort is to go to the local college auto mechanics department and try to use the locater program that they have. Like the old Motors manuals only now on CD's.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
