We are the Auto Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Chevy Tahoe Cylinder 5 misfire
Posted at Tue Nov 03, 2009 1:32 pm |
By
fillion619,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic 107000 miles
The tahoe has a misfire code P0305 which is misfire on cylinder five the truck has new cap and rotor, plugs and wires check valve springs and compression cleaned all the engine grounds inspected the wiring to the pcm look for cracked injector line running out of ideas |
Find a
car repair manual for your Chevy Tahoe Repair Question.
Posted at Tue Nov 03, 2009 4:11 pm |
By
obxautomedic,
Certified 2CarPros Technician |
  (1373) Give Feedback | Votes: 43 |
Check for vacuum leaks.
Did you check the Injector itself? and the Wire Harness. Will need Noid Light to test.
Also check fuel pressure and regulator.
Mark S
Find a
Posted at Tue Nov 03, 2009 5:40 pm |
By
fillion619,
Have Donated |
I have checked for vacum leaks and the injector and the fuel pressure is good still haven't found anything also the truck has a new distributor |
Find a
Posted at Tue Nov 03, 2009 6:14 pm |
By
obxautomedic,
Something I forgot to ask is, did you clear code after repair? If not it usually takes up too 1000 miles to clear or about 100 - 200 key starts.
If did clear code after repair here are other possible causes...
Weak Signal from Crank and/or Cam Sensor
Faulty Engine Mount
The IAC (Idle Air Control) Motor
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
