Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
1999 Chevy Suburban V8 Front Wheel Drive Automatic 206000 miles
my heater / ac fan works only on the max setting it does not work on any of the lower settings.? my gas gauge does not work and when the tank is geting close to empty it jumps around is the gauge and fuel pump one unit ? or can it be somthing else ? thank you
you need a blower resistor. it is located on the passenger lower side of the hvac box right next to the blower motor. is sounds like you also need a fuel level sender located on the fuel pump. this is seperate form the fuel pump.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
