Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1999 Chevy Suburban V8 Four Wheel Drive Automatic too mu miles
My suburban will not start. will turn over but cuts out 2-3 seconds later. will start in pm however. security light on dash stays on when it will not start. fuel pump is working. doesn't happen all the time.
Sounds like your having an issue with the security system. It could anything from the chiped key to the ignition switch or the security system module. You will probably need to take it to a qualified shop for this one as this can be very difficult to diagnos and there is very little in aftermarket manuals to lead you in the direction needed. I hope this helps and thanks
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
