Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Chevy Silverado Please help! I have to get some sense
Posted at Sat Nov 07, 2009 1:19 pm |
By
NoCarSense11,
Have Donated |
Give Feedback | Votes: 0 |
Engine Cooling problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic 150000 miles
So I get in my 1999 Z-71 & it says low coolant. So i get out and look on the pavement & there is liquid everywhere. SO I go to add more coolant and as soon as I poured it in it just came pouring right back out! My Hoses are fine, could someone please tell me what this could be so when I go to the garage I dont get ripped? My husband is in Iraq & I dont want to go to the garage & act like I have no clue & get ripped off. THANK YOU SO MUCH IN ADVANCE! |
Find a
car repair manual for your Chevy Silverado Repair Question.
Posted at Sat Nov 07, 2009 6:36 pm |
By
pear69,
Moderator |
(34) Give Feedback | Votes: 11 |
First lets see where the leak is...I am assuming you are adding coolant directly to the radiator....Start by moving your truck away from the coolant already on the ground...It's ok to move it a few feet and then shut it off..Add some water -- not coolant -- because water is cheaper. Add it slowly and pin point where it is coming from..If it is too hard to see, observe where on the fresh ground is it dripping? EX. right front - left front - front - back..
If you are adding coolant to the coolant reservoir, then add some water and look close for a crack in the reservoir tank...Let me know what you find.. |
Find a
Posted at Sun Nov 08, 2009 6:21 am |
By
NoCarSense11,
Have Donated |
I added water & it is leaking behind my belt somewhere sort of on the driver side/middle. Its not leaking slow by NO means. Its is pouring right back out just as soon as I can add it! Bless you for helping me it really means alot! Please answer back when you get a chance, Thanks a million! |
Find a
Posted at Sun Nov 08, 2009 6:22 am |
By
NoCarSense11,
Have Donated |
I have already made a small donation, & I will be making another! Thanks |
Find a
Posted at Sun Nov 08, 2009 8:26 am |
By
pear69,
Moderator |
That is where the weep hole for the water pump is located. You most likely need a new water pump. When the bearing inside of the water pump fails -(and they do around 150000 or so)- the weep hole will break open and water will spill out there. It is a good idea to change the upper, lower, and bypass radiator hoses along with the water pump. Also, changing the thermostat may be a good idea, because typically with a failed water pump there is bound to be some type of contamination in the coolant. This could cause the t-stat to stick or fail.
Thank you and bless you and your husband -- May he return soon.. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
