Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1986 Ford Ranger Vehicl...
Auto Repair2002 Ford F150 Sunroof ...
Auto Repair1963 Dodge Dakota
Auto Repair1994 Audi 90 Ac
Auto Repair1999 Dodge Dakota Won't...
Auto Repair2001 Dodge Dakota Rear ...
Auto Repair1995 Jaguar Xjs Car Won...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Chevy Silverado Engine codes P0174, P0171, and P0327
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 29, 2008 5:21 pm
By robertbassin5, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1999 Chevy Silverado 6 cyl Two Wheel Drive Automatic 5000 miles
I have a 1999 chevy truck with a rebuilt engine 4.3L V6. Engine light coming on for awhile and then going off for awhile. The engine has about 3000 miles on the rebuilt engine. But I keep getting codes P0174, P0171, and P0327. The problem that I am having is that the engine light will come on for awhile and then it will turn itself off for awhile. Can''t figure out why. My cuz works at Firestone and he ran all the checks ( Smoke test, fuel pressure check). Cause there are no vacuum leaks, fuel pressure 59 to 60 psi.,MAF sensor new, and the O2 sensors were changed last December. Like I said all these problems started after the engine was replaced and the reason it was replaced cause it spun a rear main bearing. Right before the motor went out I was pulling a boat with cruise control on, when I was approaching an overpass the motor raved up like it does with cruise control on, but when I got to the top of the overpass the motor didn't slow down like it should have so I had to stop it myself. An that's when the motor spun a rear main bearing. The repair shop said that gas got into my oil and caused the oil to thin out due to the fuel regulator going out. Any ideas??? Will driving with the light on with these codes damage my motor?
Find a car repair manual for your Chevy Silverado Repair Question.
Posted at Sat Aug 30, 2008 1:07 am
By mhpautos, Certified 2CarPros Master Technician
Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2Reputation: 518.2 (518) Give Feedback | Votes: 11
Hi there,
Your code P0327 is a faulty knock sensor. this will affect the ignition timing and if left un checked can cause piston damage due to detonation, check this out & clear all codes, the other codes are for a lean mixture, i would do the knock sensor and see if it pulls codes after that.
mark (mhpautos)
Posted at Sat Aug 30, 2008 5:03 am
When I first got these codes my cuz at firestone with he is ase certified checked the knock sensor and it checked fine.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
