Engine Cooling problem
1999 Chevy Malibu 6 cyl Front Wheel Drive Automatic 140000 miles
WHAT IS TYPICAL COST TO REPLACE WATER PUMP ON 3100V6? mY RESEARCH SHOWS THAT THE PUMP AND TIMING COVER IS OF THE SAME PART/PIECE, IS THIS CORRECT? SHOULD I HAVE THE TIMING BELT REPLACED? GASKETS? IS THERE ANY THING ELSE THAT CAN BE CHECKED/REPLACED DURING THIS PROCEDURE? I ATTEMPTED TO TAKE THE PUMP OFF BUT DIDNT GET FAR AFTER FINDING A PHOTO OF THE TIMING COVER/PUMP. i HAVE ALSO HEARD OF THE INTAKE MANIFOLD LEAKING COOLANT, IF THIS IS THE CASE WHAT IS A REASONABLE ESIMATE FOR REPAIR?
THANKS
PSORE
