Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Chevy Cavalier Brakes and computer problem
Posted at Sat Nov 21, 2009 10:59 am |
By
Koss012,
New to the forum |
Give Feedback | Votes: 0 |
Computer problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
My 99 cavalier has its ABS and EBS lights come on sparatically usually in rainy conditions. When this occurs at low speeds parking and stopping at stop lights my abs will kick in and the car won't stop usually for about 2-5 feet. I have taken my car in and had it hooked up to a dianostic check and the mechanic told me he couldn't connect with the brakes to get a reading from the car?
Do you know what the problem could be and what I could expect for a repair of this to cost? |
Find a
car repair manual for your Chevy Cavalier Repair Question.
Posted at Sat Nov 21, 2009 12:28 pm |
By
merlin2021,
Certified 2CarPros Master Technician |
                    (10364) Give Feedback | Votes: 137 |
Just because his scanner doesnt work, doesnt mean a Chevy tool wont, You do need the coe to start a dignostic, if it's a wheel speed sensor(common) you can test each one with a volt ohm meter, ohm the two leads at each sensor, reading for Chevy is 2300 ohms, then switch to volts and spin the wheel, reading should increase with speed. Worn hub bearings can cause these issues... |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
