Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Mitsubishi Galant ...
Auto Repair1999 Toyota Camry Car I...
Auto Repair1991 Nissan Maxima
Auto Repair2003 Chevy Silverado Re...
Auto Repair1997 Saturn Sc2 Replace...
Auto Repair2004 Chrysler Sebring M...
Auto Repair1996 Oldsmobile Ciera S...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Chevy Cavalier 1999 Chevy Cavalier 2.2 Hard To Start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Apr 28, 2008 8:06 am
By ray7361, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Car Is Hard to start, it takes 5 to 6 seconds of cranking to start. i have replaced fuel pump, fuel filter, fuel pressure regulator, coolant temp. sensor, plugs. Still has extended cranking. But found this out, i tried spraying wd-40 on coil packs and ignition module, i let it sit on it for a little bit, then it would start on first crank, turn ignition off, couple hours later it would start right up and let it sit over night and it would start first crank, run car for a little while and wd-40 would "wear off" and back to extended cranking. i replaced coils and ignition module with salvage yard parts but got same symptoms, also used di-electric grease on ignition parts, car once started runs perfect it has no misses and idles perfect. I also took car to Advance Auto Parts to scan for stored codes but they wouldn't scan car because the check engine light was not on, any advice would be helpful, Thanks ray7361
Find a car repair manual for your Chevy Cavalier Repair Question.
By Advertisment,
Posted at Mon Apr 28, 2008 8:24 am
By Service Writer, Certified 2CarPros Master Technician
Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3Reputation: 534.3 (534) Give Feedback | Votes: 72
Did you replace the boots that snap onto the plugs?
Posted at Mon Apr 28, 2008 9:33 am
"Boots that snap onto plugs"? Spark plug wires..if so, no.
Posted at Mon Apr 28, 2008 11:58 am
Okay, you have the other one...and yes in that case plug wires. Somtimes you can get them to act up by misting water on them when the problem isn't present to expose it.
Posted at Mon Apr 28, 2008 12:42 pm
what does "misting water" on the plug wires do, car does not have a miss ,remember if i spray wd-40 on coils and module and i guess plug wires, after the wd-40 "soaks in" it starts the first try, do you think if i changed my plug wires it will help the extended cranking?
Posted at Tue Apr 29, 2008 3:07 am
Moisture can set into the wires, not providing good spark. Thus the reason you are spraing wd-40...a moisture displacing chemical. Since spraying the fluid on them results in the condition being absent temporarily, it would give the impression of bad wires.
If there are only two cylinders that are not firing in the AM when the problem happens, it isn't going to start. Bad wire can exhibit both a missfire or a no start such as you have. Does that mean that is your solution? No.
Misting the wires when the problem is NOT happening, but they start arcing, giving a runnibillity problem or stall, will help to narrow it down.
Posted at Wed Apr 30, 2008 8:04 pm
By ph8ed4life, New to the forum
ray
I have the same problem I am trying to diagnose on a friends car, the exact same year, model, etc. It has started in this manner for years, and has gotten slightly worse lately.
Do you notice, when you are cranking it, when it finally catches and starts, it is rough to idle up and something under the hood or under the dash clicks real hard/loud?
Thanks!!!!
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
