Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Any suggestions on why my car 99 Cadillac STS keeps cutting off after I come to a stop with no warnings? Normally just starts right back up, once it took approximately 3 tries to start up.
have the codes scaned, the no warnings to me would indicate crank sensors, do not replace the tps
My 1999 Seville STS was doing the same thing. Finally it cut off and wouldn't restart. Had it taken to the dealer and they found the problem to be in the ignition switch. After the switch was repaced it hasn't happened again and it has been 2 years.
Hope this helps.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
