1999 Cadillac Concours Service Stability System Message on
FYRFYTER516
  • 1999 CADILLAC DEVILLE CONCOURS
  • V8
  • 17,100 MILES
I just bought this car from an older couple who barely drove it. It has probably been driven less than 100 miles in the last two years.
I get an intermitent 'Service Stability System' message. It will go away for a time after the car has sat for awile, usually overnight.
The ABS and Stability System dash warning lights also come on. Any troubleshooting advise?
Wednesday, May 14th, 2008 AT 9:08 AM
BUZZSAW
  • 1,198 POSTS
Scan your codes for me, off and warmer on the heater controls at the same time with your key in the on position, write them down and post them here
Thursday, May 15th, 2008 AT 12:16 AM
FYRFYTER516
Thanks Buzzsaw,
Here are the codes
PCM P0113 Current
SDM D1148 History
TCS C1242 History
TCS 1243 History
TCS 1255 History
PZM 1552 History
IRC B1983 History
Also, is there a way to reset the oil change message? I changed the oil last night and I still have it.
Friday, May 16th, 2008 AT 3:31 PM
BUZZSAW
  • 1,198 POSTS
For the oil look in your owners manual for the procedure for the oil reset
PO113 is your intake air temp sensor, its stuck in your air filter box
your TCS codes are your light problems, my book says to ck your grounds to it or the BPMV pump motor is malifunctioning( high resistance in the motor ) or the ETCBM is bad
the first thing I would try is an etcbm go to the junk yard for this its expensive new, its the control module for the abs, the bpmv is the abs valve assy behind the module
the PZM code is a disconnected battery
IRC is source voltage low B1583, which is battery low
Saturday, May 17th, 2008 AT 8:44 PM
FYRFYTER516
I'll let you know what worked.
Sunday, May 18th, 2008 AT 10:05 AM
