Auto Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 Buick Lesabre rear defrost
Posted at Tue Oct 27, 2009 9:21 am |
By
modlinmd,
Likes to hang around! |
Give Feedback | Votes: 0 |
Electrical problem
1999 Buick Lesabre
My rear defrost does not work anymore how do I fix this? |
Find a
car repair manual for your Buick Lesabre Repair Question.
Posted at Wed Nov 04, 2009 8:24 am |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
        (8952) Give Feedback | Votes: 70 |
You need to start by checking the fuse. If it's good, then you need to check for power to the switch. Let me know what you find.
Joe |
Find a
Posted at Thu Nov 05, 2009 2:18 pm |
By
modlinmd,
The fuse is ok and when I press the button to turn on the rear defrost it does lite up it just does not defrost. |
Find a
Posted at Thu Nov 05, 2009 7:12 pm |
By
Jacobandnickolas,
I have a feeling the switch itself is bad. What happens is they turn on, but when they are put under a load, they can't provide enough power. Regardless, move back to the window where the defroster grid plugs in. Turn the power on and see if you are getting 12 volts to the grid at the power supply. If you are not, it could be a couple problems, a break down in the wiring to the grid, or the switch itself. Make sure there is 12 volts going both in and out of the switch before moving on to the other steps. Also, make sure the swith output is connected to the wiring when checking it so we know if the switch is the problem.
Let me know what you find. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
