Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1999 BMW 318 engine light is on
Posted at Tue Oct 27, 2009 2:51 am |
By
bmw318SE,
New to the forum |
Give Feedback | Votes: 0 |
Computer problem
1999 BMW 318 4 cyl Two Wheel Drive Manual 87000 miles
I have had the computer scanned. It tells me there is an air leak on the fuel system. Have checked from the air filter to engine cannot find fault can you help, please.
The code readout read;
code 171 check fuel supply system (EUIII code: P0170)
thank you.
tony (london, U.K) |
Find a
car repair manual for your BMW 318 Repair Question.
Posted at Tue Oct 27, 2009 9:19 pm |
By
Dr Loot,
Forum Helper |
(82) Give Feedback | Votes: 12 |
| bmw318SE wrote: | Computer problem
thank you.
According to my OBDII manual, a code 171 indicates that the system is running lean. This is not necessarily from an air leak. It could be a faulty mass air flow meter, or could be something as simple as plugged injectors. My first step would be to put some injector cleaner in the fuel tank. My personal choice would be BG44K, although it is not carried in many parts stores. After that, I'd try to find a friend with the same car and temporarily swap MAF sensors with him to see if that cures the problem and moves it to his car. Finally, you can check for vacuum leaks by spraying starting fluid around your hoses and listening for an engine rpm change. The boot from the throttle body to the mass air flow sensor is the most likely culprit. Inspect it carefully.
Good Luck
Dr. Loot's Assistant |
Find a
Posted at Tue Nov 03, 2009 8:11 am |
By
bmw318SE,
New to the forum |
thank you for your reply.
I have changed the mass airflow meter.
Can you tell if the engine light that is on can be reset without a diagnostics computer.
thank you |
Find a
Posted at Tue Nov 03, 2009 9:23 pm |
By
Dr. Hagerty,
Certified 2CarPros Master Technician |
(83) Give Feedback | Votes: 20 |
No, it cannot. It will take a scanning device to reset the light. Also check the tank vent valve. Go to Realoem.com for the exploded view of the valve and it is located on the intake manifold. Part # 11-15-7-501-567 |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
