Brakes problem
1999 Acura TL 6 cyl Front Wheel Drive Automatic 98,000 miles
Hello
I have tried many different combinations on this car front bkakes in the past. OEM rotors with Ikebono pads, worked great for about a year and a half then rotors worped.
Tried After market rotors ( made in China) with Ikebono pads. The rear still has Ikebono pads with the OEM rotors. It was bad from the start. When I applied brakes felt a vibration, like a hummning in my steering wheel. After about 6 months they were worped.
Recently I tried resurfacing the same aftermarket rotors with the OEM pads. It felt smooth an OK if you are braking at slow speeds. But if I am doing over 40MPH when applying brakes I feel a vibration worse than the first one.
I know these cars have don't design the best brakes in the market for that year, but what can I do or what combination or brand of front rotors or pads I can use to correct this problem once and for all?
Thanks for your help!!
Regards
Tony
