Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1999 Acura TL 6 cyl Front Wheel Drive Automatic 170000 miles
I was driving from work and I approached a buddies house and as I slowed my car down I had not even gotten to the curb to park and the car died. I have lights and Battery seems to be working. Also all fuses are ok. I have fluid and About half a tank of gas.
I try to start the car and it almost sounds like it is trying to start/turnover. It almost sounds normal to me. So I looked arounf the car and I just dont know whats wrong. I sprayed some starter fluid and the car will turn over and again die. I wonder if for some reason im not getting fuel. No lines are leaking. Or maybe its the fuel pump. If anyone knows or has suggestions on the problem. Any info would be much appreciated.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
