Engine problem
1999 Acura CL 6 cyl Two Wheel Drive Automatic 12800 miles
can i change the valve cover gaskets without taken the intake manifold off
Yes you can. The head gasket requires the intake to come off. Be sure that when you replace the valve cover gasket that you replace the grommets on the plug holes as well.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
