Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1996 Ford F150 Put The ...
Auto Repair1996 Mitsubishi Eclipse ...
Auto Repair1991 Ford F150 Truck Fa...
Auto Repair2000 Toyota Camry Timin...
Auto Repair2000 Chrysler Cirrus Po...
Auto Repair2008 Ford F150 Static E...
Auto Repair2003 Ford Explorer Need...
Auto Repair More Repair Topics...
Car Repair Advice by Professional Automotive Experts
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Volkswagen Jetta Fuel Pump
Goto page 1, 2  Next
Posted at Sat Nov 14, 2009 11:26 am
By vdub98, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1998 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic
So, i'm having a hard time starting my car when it gets really cold. Do you think the fuel pump could be the problem? Or a fuse, relay?
Find a car repair manual for your Volkswagen Jetta Repair Question.
Posted at Sat Nov 14, 2009 12:56 pm
By KHLow2008, Certified 2CarPros Technician
Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9Reputation: 5152.9 (5153) Give Feedback | Votes: 69
Hi vdub98,
Thank you for the donation.
Is this a gas or diesel engine?
Posted at Sat Nov 14, 2009 1:01 pm
KHLow2008 wrote:
Hi vdub98,
Its a gas.
Posted at Sat Nov 14, 2009 1:41 pm
The most common cause for difficult starting when cold would be the Engine CoolantTemperature sensor.
Fuel pump is not likely to be the cause.
Posted at Sat Nov 14, 2009 2:07 pm
I replaced that about 3 weeks ago, because the check engine light came on and it gave me that code about the coolant temperature sensor. I don't know what else could it be.
Posted at Sat Nov 14, 2009 9:16 pm
After replacement of the ECT, was the trouble code
cleared and did the CEL return?
Was the ECT used OEM and was any reading tests carried out on it?
When it was dificult to start, was the engine cranking speed good?
Did you test the fuel pressure?
Are the spark plugs conditions good?
Any idea of the spark plugs burning condition?
Posted at Thu Nov 19, 2009 12:36 pm
After i replaced it, the code went away and it never came back anymore as of now that i know of.
The cranking was good when i try to start it, i did notice a little bit of black smoke coming out from the exhaust. But it then went away.
I havnt had the chance to do the fuel pressure test, but i will soon. Maybe tomorrow..
I put in new spark plugs about two years. I got those bosch fusion, which they were expensive. I replaced the plug wires too. I would have to take one out to see what the burning condition is, it shouldnt be that bad...
I did had some problems before with my idling because it was a little high. So i cleaned the throttle body and replaced the IAT sensor and it stopped doing that.
Last year the long block got replaced. I put a new one. I'm trying to think whatelse have i changed. Well, i will let you know if i can think of anything else.
I really appreciate ur help.
Posted at Fri Nov 20, 2009 3:58 am
Black smoke during cranking indicates incomplete combustion or a rich condition.
Btw which engine variation do you have?
Posted at Fri Nov 20, 2009 11:54 am
U mean like valves and all that kind of stuff?? Is a single cam with 8 valves 2.0L.
Posted at Fri Nov 20, 2009 12:36 pm
Sorry for the confusion but you did answer it correctly. What I meant was the engine capacity.
The exact engine type is necessary to get the correct information.
Let me know the fuel pressure once you have tested it.
What is the mileage? If the mileage is high, get a compression test done as well. Low compression would cause difficult starting as well.
Do you have any overheating or coolant losses issues?
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
