Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1998 Plymouth Breeze 4 cyl Two Wheel Drive Automatic 165,00 miles
I purchased a plymouth breeze with a 2.4Ltwin-cam that will not run. It cranks over easily on the starter. (so easily that it is obvious there is no compression here) The timing cover was removed and I suspect the belt has been removed and replaced with out correct alignment of the cams. The thought of bent valve stems has crossed my mind. So my question is 1. Can the pistons hit valves when incorrectly timed. 2. what is the correct timing procedure for this motor? Thanks CZ
Hi:
I believe it is possible for the piston to hit the valve. If the valve cover is off, turn check for a valve that may be bent, not allowing the valve to close.
Also,If you look on this page, you'll find "Popular Site Links." Go to "Drive Belt Routing Diagrams." There you will find the timing info/
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
