Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1998 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic 170000 miles
My 1998 oldsmobile bracvada seems to have what I belive is a problem with the ignition switch. Recently I've had problems maintaining a full charge on the battery, the battery tests good and so does the alternator. I think that the ignition switch may not be shutting down completeley and it may be leaving some accessories powered up and that may be what is causing the battery drain. I've noticed that sometimes the key is had to insert into the ifgnition switch and I have mess with it to get it in and turn the car on. I've also discovered that I can pull the key out while the engine is running. Please advise if this may be the problem or if there is something else going on.
Find a car repair manual for your Oldsmobile Bravada Repair Question.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
