Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Engine Cooling problem
1998 Mitsubishi Montero 6 cyl Two Wheel Drive Automatic 100 miles
I have a 98 v6 Montero Sport. My wife drove the car without oil and now the car makes an incredible noise in the motor and overheats (but it still drivable). Does the engine go totally bad? Or I can replace few parts and it will be fine again? If so, what parts are more likely to be damaged?
If the noise is from the engine lower part and increases in level, you need to replace the con-rod and bearings and grind the crankshaft. It is driveable now, but will jam up anytime. I would not drive it to prevent more damage.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
