Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Lincoln Continental ...
Auto Repair2000 Honda Accord Car Wi...
Auto Repair1995 Toyota Tercel Idle ...
Auto Repair1992 Ford Mustang Won't ...
Auto Repair1995 Chevy Impala Car St...
Auto Repair1987 Chevy Cavalier Loss...
Auto Repair1992 Ford Mustang Car Wa...
Auto Repair2002 Pontiac Bonneville ...
Auto Repair2000 Jeep Cherokee Camsh...
Auto Repair2005 Pontiac Grand Am St...
Auto Repair1995 Geo Prizm Rubbing N...
Auto Repair1995 Chevy Cavalier Plea...
Auto Repair1993 Chevy S-10 Timing Belt
Auto Repair1996 Chevy Cavalier A/c ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Mazda 626 AC causes odd symptoms
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 09, 2008 4:46 pm
By plsmoothy, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
1998 Mazda 626 4 cyl Front Wheel Drive Automatic 132000 miles
I own a '98 Mazda 626 with 130,000 miles. I'm hoping someone out there can shed some light on this situation. Its important to note that the following symptoms occur only when the AC is on and the car is in stop and go traffic. The car runs fine when the AC is not engaged or when the AC is on under highway conditions 1. car loses approximately 5-7 hundred rpm when the AC cycles on. Is this high? 2. I live in Southern California. The summers are hot. After driving the car in stop and go traffic I'll come to a stop (at a light for instance) and the idle speed will drastically fluctuate between the normal idle speed of approximately 7-8 hundred rpm to almost 0. In other words the car will almost stall. If I turn off the AC compressor the fluctuating stops. 3. When it gets to that point, the AC will stop cooling and the car will almost overheat. Again, these symptoms occur only when the AC is on and the car is in stop and go traffic. Any help is greatly appreciated.
Find a repair manual for your Mazda 626 Repair Question.
By Advertisment,
Posted at Fri May 09, 2008 10:47 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9Reputation: 401.9 (402) Give Feedback | Votes: 11
Hi there,
your engine should have an A/C idle up system fitted, this increase the engine idle speed when the A/C is turned on, i would have this inspected first, As for the overheating, make sure that the cooling fans are coming on your thermostat is working and the radiator is cleaned and flow tested. Start here.
Mark (mhpautos)
Posted at Sun May 11, 2008 9:43 am
Do you think I should consider installing a new AC compressor? Why does my AC cause my engine to lose so much power? The rpm's drop approximately 7-8 hundred when the AC is engaged.
Posted at Sun May 11, 2008 2:25 pm
Hi there,
If the A/C compressor is running tight due to a bearing problem the load will cause the idle to drop. i would be getting the comp inspected.
mark (mhpautos)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
