Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1996 Chevy Blazer Cabin...
Auto Repair1990 Honda Accord Accor...
Auto Repair1989 Ford Probe Headlights
Auto Repair1987 Nissan Sentra Car ...
Auto Repair2001 Ford Taurus Over S...
Auto Repair2002 Other Toyota Models...
Auto Repair1998 Honda Accord Starting
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Jeep Wrangler Blinker Noise
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Jul 05, 2008 7:49 pm
By blackhawk1008, Likes cars!
Give Feedback | Votes: 0
Noises problem
1998 Jeep Wrangler 4 cyl Four Wheel Drive Manual
Hi, I own a 1998 jeep wrangler, and have only had it for about two weeks and just today it started to make a ticking noise similar to when you have the turn signal on but it is a lot faster. When you turn one of the signals on the noise slows down and is in the normal pattern but when the signal turns off it speeds up again. Also the noise stops altogether when you hit the brakes but when you release the pedal it starts again. i have searched the internet but cant get a straight answer so i was wondering if you had any ideas on how to fix this problem.
thanks
Find diagnostic tools, replacement parts or locate a car repair manual for your Jeep Wrangler Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 2:17 pm
By Brewer, Tech level 1
has anyone helped you in person to do a visual of the "blinkers" from the outside while this problem is occuring? Meaning, while it is going on, check to see if the lights are actually blinking when they are not supposed to be.
It could be something as small as a burnt flasher, or something as large as a computer getting crossed signals from some sensors. First things first though - need you to check the visual occurrance outside to see if there are more symptoms of your problem.
Posted at Sun Jul 06, 2008 8:38 pm
thank you for the advice. I checked the blinkers and they still work fine inside the car and the outside lights work fine to. Could there be any other cause of this problem one site that I found said it could be a broken relay but I still don't know how to fix it is there any place I could purchase a owners manual for car, because it came without one.
Posted at Sun Jul 06, 2008 9:27 pm
an owners manual would be a great place to start.
If you want the type that comes with the vehicle, go to any jeep dealer in your area. A 98 model should still be very easy to get.
IF you want a more in depth but less lamen termed manual, then I would check out something like a Chilton's manual which can be obtained at virtually any auto parts store. (I would even think about checking one out at the local library too as many of these can be found there as well - and if you only need it once in a while, then it might be the cheaper avenue)
sadly, the "blinkers" are a part of the electrical system, and what this means is that the cause of your problem could be in a multitude of different areas. My gut is on the relay, but if not, it could also be anywhere else along the wire line. Under the dash can sometimes be a big problem for jeeps as they tend to develop leaks over time from the front windshield frame. If this is your case, then the first place to start is where there is water... because a leak could lead to rust. Rust leads to malfunctioning stuff. First fix the leak, then fix the malfunction. If you don't fix the leak - the malfunction will come back, but this time it might be on a different circuit.
Now - that said, I'm not trying to scare you away from trying to sort the problem on your own - in fact just going through the circuit will probably teach you more about how your jeep is built, and any problem areas to watch for in the future.
To save you a little time, the flashers are generally kept in the fuse box under the dash. (At least in models from 87 - 95) I would be shocked if the 98 model didn't have it in the same place.
let me know if it wasn't the flasher and I'll try to help you find the bug elsewhere. the good news is that the lights are still functioning as they are supposed to.
Good luck
Posted at Mon Jul 07, 2008 5:38 am
thank you very much for all of the help that you have given me and I will contact back whether or not the problem is fixed and again thank you very much for all of your help I really appreciate it
Thanks
Posted at Mon Jul 07, 2008 5:44 am
I forgot to ask if the flashers are under the dash how will I access that box there is a panel on driver side down by the floor is that the fuse box you are talking about or is it somewhere else
Posted at Mon Jul 07, 2008 11:25 am
the fuse box is on the drivers side - underneath. I can't say for sure if what you are looking at is the correct panel to remove or not. Generally they have a very distinct appearance, no more than 5 or 6 inches squared that you pop off and access. Generally the fuse box layout is on the backside of the panel you remove as well.
If you remove this panel (which should be just a pull out panel - most have a finger hole so you can pull out on) you should be able to have full access to the fuses / flashers.
Posted at Mon Jul 07, 2008 3:18 pm
ok I was looking at the wrong one thank you for the clarification
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
