Engine Mechanical problem
1998 Hyundai Accent 4 cyl Front Wheel Drive Automatic
The problem i have with the car is at the beginning it would run fine and after awhile it would bog out no power,I would shut the key off for a second and turn back on would would great for a little whil longer.took it for a 2 hour drive and now it is running rough all the tiime like a dead plug or something and engine light flashs now do you have any ideas befor i spend alot of money on this
Thanks
Find a
repair manual for your Hyundai Accent Repair Question.
Posted at Fri Apr 18, 2008 3:32 am
By
Advertisment,
Find a
I'll assume that you checked that it isn't a dead plug. If this problem is apparent at idle, when you try to snap the throttle ie: slow, rough response, try uplugging the mass air flow sensor. If throttle responds much better, replace it.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
