Engine Performance problem
1998 GMC C1500 V8 Four Wheel Drive Automatic 110000 miles
I have a problem when I go to accelerate some times. It stutters quite badly for a short period of time. It seems to be mostly when you are moving and then depress the accelerator to speed up. When I got it the check engine light was on and the mechanic said the O2 sensors were responding slowly but no check engine light since then. Also, if you put it to the mat from a stand still, it seems to hesitate and then it takes right off. I don't know if this is related but when the air conditioner is running it starts idling rough as well. Thanks for your time.
Rick
