Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Car Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Auto Parts
Vehicle Repair Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2004 Chevy Trailblazer
Auto Repair2003 Pontiac Aztek Brakes
Auto Repair1995 Acura Vigor Acura ...
Auto Repair1976 Other Nissan Models...
Auto Repair1997 Buick Skylark Heat...
Auto Repair1997 Chevy Cavalier Eng...
Auto Repair1986 Chevy S-10 Carb Va...
Auto Repair2000 Gmc Yukon A/c Comp...
Auto Repair1995 Ford Explorer Od L...
Auto Repair1992 Honda Accord Somet...
Auto RepairWho Let The Dogs Out?
Auto Repair1995 Acura El Acura El ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Other Websites
Auto Repair Computer Repair Questions
Auto Repair Search Engine Optimization
Auto Repair WhyOurWorld.com
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Ford Taurus Transmission and speedometer problem
Welcome to our question and answer forum were over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue May 13, 2008 5:57 pm
By 5f36P2, Have Donated
Give Feedback | Votes: 0
Transmission problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic 61,396 miles
I recently bought a 1998 Ford Taurus with the Duratec 200 h.p. engine. As I was driving the " overdrive " light started flashing, and the speedometer dropped to "zero" for a few seconds and then started working intermittently. The transmission then felt like it slipped into "neutral" for a few seconds and revved up to 3500 rpm's. A second or so later the car slipped back into gear. I brought the car to my mechanic and he said the problem was caused by a faulty speed sensor. He replaced the sensor and for a few hours everything was fine. The next day the same problem with my speedometer and transmission started all over again, only this time the "overdrive " light did not flash. I went back to my mechanic and he said nothing was showing up on his diagnostic test. He referred me to a transmission specialist who also ran diagnostics and said nothing was showing up. He suggested that maybe the problem was that the transmission was heating up due to a clogged or cracked transmission filter and that I should replace both , even though both mechanics said the fluid looked fine. Desperate, and running out of money, I changed the transmission fluid and filter . The same problems still kept happening with the transmission and speedometer. About a week later , the "overdrive " light started blinking along with the transmission and speedometer problems, only this time the "overdrive " light would only stay on for about a minute and then turn off : however the transmission continues to feel like it is slipping for a few seconds as it revs up to about 3500 r.p.m.s and the speedometer fails for a short time over and over. The other day , as I sat in my car idling in "park" I revved the engine and as it neared the 4000 r.p.m. mark it started to lose r.p.m.s no matter how hard I stepped on the accelerator. It was almost as if there was some type of "governor" on the car that prevented it from going over a certain speed. I am at my wits end with this problem and this is our family's only car. I can not afford to bounce from shop to shop as this will cause a tremendous financial burden on us. Could you please help us .
Respectfully,
J.
Find a repair manual for your Ford Taurus Repair Question.
By Advertisment,
Posted at Thu May 15, 2008 5:25 pm
By flexy5, Tech level 5
Reputation: 52Reputation: 52Reputation: 52 (52) Give Feedback | Votes: 6
I would be interested to know what the code is for the O/D light now. There are a couple of things to be considered. The first thing that comes to mind is a wiring concern. There may be a problem with the wire connector at the sensor. Check the connector to make sure it is seated properly. Also inspect the wire harness from the sensor and make sure it is not grounding or chafing on anything. This could also cause a problem with the sensor readings. The symptoms are typical of a failed speed sensor, but if it was replaced and we still have the same issue, we need to start looking elswhere. It is possible that the new sensor is bad, but it is a rarety. As far as the reving in park, it does have a rev limiter built into the PCM. It is not adjustable.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
