Auto Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1998 Ford Ranger My timing belt broke going down the road
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Wed Jul 16, 2008 10:59 am |
By
joemicbur,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1998 Ford Ranger 4 cyl Two Wheel Drive Manual 212000 miles
Please tell me how to turn the bolt on the crank shaft pully so I can loose the bolt and take the pully off? The entire engine turns when I turn the bolt. I also need to know how to get the motor in time before I place the new belt on the pulleys. TDC is what I'm looking for,but how do I determine that. I know that this is very important, so I need some real expert advice here.
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Ford Ranger Repair Question. |
Posted at Wed Jul 16, 2008 2:26 pm |
By
obxautomedic,
Moderator |
 (43) Give Feedback | Votes: 5 |
| joemicbur wrote: | Engine Mechanical problem
Please tell me how to turn the bolt on the crank shaft pully so I can loose the bolt and take the pully off? The entire engine turns when I turn the bolt. I also need to know how to get the motor in time before I place the new belt on the pulleys. TDC is what I'm looking for,but how do I determine that. I know that this is very important, so I need some real expert advice here. |
You will probably need to rent a 3/4 Electric Impact Wrench to get the Crank Shaft Bolt out.
You will need to put the #1 Cylinder at TDC on Compression Stroke.....
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Thu Jul 17, 2008 6:09 am |
By
obxautomedic,
Moderator |
| joemicbur wrote: | | I know that TDC must on the compression stroke, but how do I determine the compression stroke? |
Do you have a compression tester? If not what you can do is cover the plug hole with something, if you can your finger works great, then turn the crank pulley until you feel the air being pushed out. Look at the mark on the crank and make sure it lines up.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
