Auto Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Ford Ranger engine barely runs at idle cycles when acc
Posted at Fri Nov 06, 2009 5:55 am |
By
chancebase,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1998 Ford Ranger 4 cyl Two Wheel Drive Manual 60000 miles
Was running fine when I parked in garage. When I started two days later engine idled exteremly rough,extreme shaking, engine near stalling. When accelerator is depressed halfway down engine begins to stall then speeds up then stalls then speeds up. This cycling continues as long as accelerator in depressed. I changed gas filter. I also checked fuel pressure at injector rail and found pressure within specs when engine not running key on. When engine barely running at idle fuel pressure increased but still within specs. What do I need to check next? |
Find a
car repair manual for your Ford Ranger Repair Question.
Posted at Fri Nov 06, 2009 8:15 am |
By
racefan966,
Certified 2CarPros Technician |
               (1628) Give Feedback | Votes: 31 |
Have you checked the air filter to see if anything is in it like a mouse nest or anything? If this checks out ok then if you would unplug the Mass Aif Flow meter and start it and see if idles ok then. Get back to me with what you find. |
Find a
Posted at Fri Nov 06, 2009 10:40 am |
By
chancebase,
Have Donated |
Had already checked filter etc.
Uplugged mass air flow meter as you instructed.
Started Engine and idled and ran engine. Runs normally at idle and when accelerated. I take it the mass air flow meter needs replaced. |
Find a
Posted at Sat Nov 07, 2009 6:46 am |
By
racefan966,
Ok if unpluging the mass air flow sensor makes it run normal or better then yes it needs replaced or maybe just cleaned. You can try cleaning it with mass air flow cleaner first. Let me know how it goes. |
Find a
Posted at Sun Nov 08, 2009 6:32 am |
By
chancebase,
Have Donated |
I cleaned mass air flow sensor with approved cleaner. "Didn't do the trick." Replaced sensor, problem solved, engine running great. I want to thank you for sharing your time and knowledge it is greatly appreciated!
Thank you!!! |
Find a
Posted at Tue Nov 10, 2009 7:53 am |
By
racefan966,
Great glad to hear it is running as it should again. If there is anything else you need just ask. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
