Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Engine Mechanical problem
1998 Ford Mustang V8 Two Wheel Drive Automatic 63000 miles
I smell raw fuel at engine idle and it's real strong, I looked under the car but don't see any leaks but when you pop the hood you can tell there's definetly an issue.
look around and on fuel injectors and fuel rails for gas leak.if leaking alot you will se a pudle od definitely wet injector or on fuel lines rails etc.also check it with engine running ,use a flash light to spot it easier.good luck
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
