Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Car Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Auto Parts
Vehicle Repair Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1990 Buick Century Car ...
Auto Repair2002 Chrysler Pt Cruiser...
Auto Repair1997 Mercury Villager
Auto Repair2000 Toyota Rav4 Rav4 T...
Auto Repair2004 Chevy Trailblazer
Auto Repair2003 Pontiac Aztek Brakes
Auto Repair1995 Acura Vigor Acura ...
Auto Repair1976 Other Nissan Models...
Auto Repair1997 Buick Skylark Heat...
Auto Repair1997 Chevy Cavalier Eng...
Auto Repair1986 Chevy S-10 Carb Va...
Auto Repair2000 Gmc Yukon A/c Comp...
Auto Repair1995 Ford Explorer Od L...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Other Websites
Auto Repair Computer Repair Questions
Auto Repair Search Engine Optimization
Auto Repair WhyOurWorld.com
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Ford Mustang Engine Misfire
Welcome to our question and answer forum were over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 09, 2008 3:50 pm
By bcf, Have Donated
Give Feedback | Votes: 0
Electrical problem
1998 Ford Mustang V8 Two Wheel Drive Automatic 103000 miles
My local service station says I have engine coolant leaking around the manifold or through the intake (on the service report it says the intake is leaking coolant). This was the report before my engine misfire problem began. When I brought the car back in for misfire, they said it needed new wires, and a new number 4 plug and that I needed a redesigned intake manifold. They said coolant was leaking into number 4 and it would continue to corrode and misfire. This was going to be quite expensive (roughly $1600), so I opted for now to just put in the new wire set and new number 4 plug. They noted on the service report that the misfire would come back. What do you make of the problem? Could this remain just a problem for the number 4 plug and be some time before it happens again, and if so, if I did not want to make a major repair at this point, why not just do-it-yourself replace number 4 each time. Or, is this likely a leaking problem that will spread. The service station said this was a common problem with Ford Mustang engines.
Find a repair manual for your Ford Mustang Repair Question.
By Advertisment,
Posted at Fri May 09, 2008 5:56 pm
By mustang87, Tech level 3
(17) Give Feedback | Votes: 1
do you see any water leaks visualy?can u smell atifreeze?check oil for water and oil mix.best way to know is if u remove oil filler cap ,look under cap,is there a tan muddy brownish residue on there? if not your ok .also check dip stick for same color .if you had a bad lower intake gasket failure all your motor oil would be mixed water and oil and car would be overheating and shaking.your mechanic is trying to ripp u off.1600 bucks is way over priced for that work.normally u just need gaskets not the whole intake.just tune up your car with all new plugs and wires.also might be a number 4 coil bad if the rest doesnt work.good luck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
