Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Gmc Sierra Coolant...
Auto Repair2002 Honda Accord Emerg...
Auto Repair2001 Saab 9-3 Repair Que...
Auto Repair1995 Gmc Jimmy Vents Do...
Auto Repair1995 Nissan Truck Oil
Auto Repair1999 Gmc Sierra Low Idl...
Auto Repair1996 Chevy Cavalier
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Ford Escort Problems getting fuel
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Oct 07, 2008 12:10 pm
By bobbyerwin, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
My problem seems to be fuel or sensor related. I will be driving, and then it will start stalling out, like its not getting gas. I push the accellerator, and it doesnt rev up. When I turn off the ignition, it will start right back up and run normal. It was doing it occasionally, maybe once a day or couple of days. Now it is doing it non-stop, maybe every mile. I got the car scanned at AutoZone. The 3 codes it gave was P1131, P1132, and P0455.
I took it to a mechanic, along with the codes. The mechanic wont even look or listen to the codes. He said he will do his own work. No scanning. Said he will check to see if there was water in the tank. Then check fuel pressure, etc. Sounds expensive.
So what is your take on this?
Find a car repair manual for your Ford Escort Repair Question.
Posted at Tue Oct 07, 2008 1:54 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
P0455= Evap system gross leak detected, this is usually a bad gas cap. Start there and the other might take care of themselves, 1131 and 1132 are 02 sensor not switching and one is lean(31) and the other is rich(32). Try a new gas cap.
Posted at Wed Oct 08, 2008 8:37 pm
The problem did not fix with the new gas cap.
Posted at Thu Oct 09, 2008 1:39 pm
The other codes contradict each other, one says 02 sensor bank 1 sensor 1 learn, and the other, rich! Did you get gas at a different station? Contaminated gas is a possibility. If not, Check fuel pressure and 02 sensors.
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
http://www.2carpros.com/affiliate/uid/merlin2021_1
Tools available here!
Posted at Tue Oct 14, 2008 6:22 am
By racefan966, Moderator
Reputation: 75Reputation: 75Reputation: 75Reputation: 75 (75) Give Feedback | Votes: 3
After you check you fuel pressure if it is good then go back to your local parts store and buy a can of mass air flow cleaner and clean your mass air flow meter. It is simple you just unplug it remove it spray the inside down really good and put it back. Some times this will get dirty and not read correctly and the tollorances on the ford computer for lean and rich are a bit tight. Hope this helps let us know ok.
Posted at Tue Oct 14, 2008 9:55 am
It is actually doing better since the gas cap. I had another problem which was adding to the motor losing power. It seems I have a water leak at the heater core. It never did run hot, but hotter than normal and when it did, the motor would cut out on me. I need to change the heater core. But other than that, now it will run rough at red lights, and sometimes it will jerk going down the hwy.
Posted at Tue Oct 14, 2008 5:22 pm
Like I said clean the mass air flow unit it is a very simple thing to do as I have already explained and it may make it run like normal again.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
