Engine Performance problem
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic 120000 miles
For about 7 months my car has been stalling occasionally but it is getting worse. Recently a water leak formed and I changed the water pump, also when i did that replaced the timing belt and tensioner.When it stalls there dosent seem to be any specific trigger. It might do it at idle or when I am going sixty. Under power or when I am coasting. When not at idle it will usually recover and keep running if i put my foot down. It runs a little rough at idle but storng under power (when it is not stalling). the car is sending a 0106 error code. The car also got a new fuel pump a year ago. Please help
Find a
repair manual for your Dodge Stratus Repair Question.
Posted at Tue May 13, 2008 8:09 pm
By
Advertisment,
Find a
That code is for the Baro/Map sensor, if it is going bad, it can definitly do the things you describe. Depending on what engine , it should be located on the intake manifold
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
