Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Dodge Neon poor performance
Posted at Fri Nov 06, 2009 9:24 am |
By
98NEONRT,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Performance problem
1998 Dodge Neon 4 cyl Front Wheel Drive Manual 98654 miles
I was driving home and my neon just lost power, it would not accerate at all, I had to baby it home in first gear, now the car is turbo (aftermarket) i didn't install it I brought it off my friend, it ran well for 2 months then all of sudden it happened. So I replaced the injectors and nothing, the engine check light came on and from what I was told it said misfired. |
Find a
car repair manual for your Dodge Neon Repair Question.
Posted at Fri Nov 06, 2009 10:57 am |
By
jdl123,
Have Donated |
                        (2518) Give Feedback | Votes: 60 |
Welcome to the forum, how long since a tune-up? what was the actual code? Obd2 code should tell which cylinder has a problem, unless multiple misfire. Use a gage and check fuel pressure. I can't help you with the turbo, if that is the issue. |
Find a
Posted at Fri Nov 06, 2009 6:07 pm |
By
98NEONRT,
The code was multiple misfires, I replaced the plugs, wires, but didn't do the core pack, the turbo is fine it just wont get the correct fuel, what is the correct pressure (fuel) for this car? Like I mention it ran great then all of a sudden lack of power & check lite on. |
Find a
Posted at Fri Nov 06, 2009 6:09 pm |
By
98NEONRT,
can i put a 2000 neon fuel pump & regulator in my 98 neon? and does the regulator have more psi then the stock one in my 98? |
Find a
Posted at Sat Nov 07, 2009 6:50 am |
By
jdl123,
Have Donated |
Manufacturer specs for your vehicle, fuel pressure, 48psi, nonturbo. The turbo manufacturer may have their own web site, where you can get their specs. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
