Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Nissan Altima
Auto Repair1994 Pontiac Grand Am M...
Auto Repair1993 Buick Lesabre Heat...
Auto Repair1997 Chevy Malibu Rough...
Auto Repair2001 Ford Ranger Spark ...
Auto Repair1984 Chevy Truck
Auto Repair2000 Dodge Dakota Flasher
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Dodge Dakota Dieing at times
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Oct 10, 2008 1:28 pm
By phils, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1998 Dodge Dakota 6 cyl Two Wheel Drive Automatic 97870 miles
I have a '98 Dakota with a 3.9 V-6 engine. It will run good sometimes and then all of a sudden it might die, it might just go to missing. It will usually start back up in just a short time. It will sometimes set a PO351 code and sometimes will have a random misfire on all cylinders. We have replaced the crank sensor, cam sensor, plugs, coil and coil wire. I have talked to a tech that works for chrysler and he tells me he has a '97 Jeep doing the same thing and has been unable to fix this problem.
If you can be of any help, I would certainly appreciate it.
Thanks in advance
Find a car repair manual for your Dodge Dakota Repair Question.
Posted at Tue Oct 21, 2008 3:35 pm
By Jacobandnickolas, Moderator
Reputation: 105.1Reputation: 105.1Reputation: 105.1Reputation: 105.1Reputation: 105.1 (105) Give Feedback | Votes: 5
Hi:
I looked up the code and I'm finding a potential ignition coil problem #1 primary circuit problem. First, disconnect the coil and check the connections for corrosion or damage.
IF there is no problem there, you need a scan tool. With the ignition switch on, atuate coil number 1. With an external volt meter, check the coil connector, auto shut down (ASD) relay output circuit (Dark green/orange wire). If voltage is 10 volts or less, repair open ASD relay output circuit.
If you get to this point without satisfaction, let me know and we'll continue.
Let me know if this helps, or if you have any other questions.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
