Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1998 Dodge Dakota CODE p0443
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Aug 05, 2008 6:36 pm |
By
tedkilroy,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1998 Dodge Dakota 6 cyl Two Wheel Drive Manual 140K+ miles
Could someone please give me a hand, bought a 98 dakota a few months back and now I am having mechanical problems with it. V6 stnd and in a ll gears it will lose power and backfire when it wants, just tuned it up plugs/wires.
Took it to AutoZone and had "check engine light" scanned and it came up with code P0443 which almost everywhere online says P0443 EVAP Canister Purge Control Solenoid.
I bought a purge control solenoid from AutoZone and installed it myself, but still having same problem and the check engine light stayed on. Placed a little soap and water on 2 rubber hoses that connect to solenoid as far down as I could, but could not detect any leaks.
Any suggestions?
| Find a
car repair manual for your Dodge Dakota Repair Question. |
By
Advertisment,
| Find a
Posted at Tue Aug 05, 2008 6:55 pm |
By
obxautomedic,
Moderator |
  (53) Give Feedback | Votes: 6 |
| tedkilroy wrote: | Engine Mechanical problem
Took it to AutoZone and had "check engine light" scanned and it came up with code P0433 which almost everywhere online says P0443 EVAP Canister Purge Control Solenoid.
Any suggestions? |
The code you had pulled is listed below....
P0433 Heated Catalyst Efficiency Below Threshold
The back firing usually indicates a timing problem. Check the timing.
| Find a
Posted at Tue Aug 05, 2008 7:57 pm |
By
tedkilroy,
Likes cars! |
Made a mistake the code is P0443, please suggest a remedy, thanks.
| Find a
Posted at Thu Aug 07, 2008 1:16 pm |
By
obxautomedic,
Moderator |
| tedkilroy wrote: | | Made a mistake the code is P0443, please suggest a remedy, thanks. |
Sorry for delay was out of town.
Did you hook up a scanner and clear the code?
Have you checked the vacuum lines?
| Find a
Posted at Thu Aug 07, 2008 6:42 pm |
By
tedkilroy,
Likes cars! |
Well, no I have not cleared the code since the problem still exist. I followed the 2 hoses that come out of the Purge Control Solenoid, one goes to the TBI and the other under the hood. It is this one that I followed and notice it goes from a 5/8" rubber hose to a smaller diameter more plastic hose all the way to some sort of box the size of the catalytic convertor.
It has a plastic sheathing cover to it so i coulod not locate a tear in the hose. Called Autozone and was told they only carry "rubber" hose and not aware of a plastic smaller diameter hose.
| Find a
Posted at Fri Aug 08, 2008 12:56 pm |
By
obxautomedic,
Moderator |
| tedkilroy wrote: | Well, no I have not cleared the code since the problem still exist. I followed the 2 hoses that come out of the Purge Control Solenoid, one goes to the TBI and the other under the hood. It is this one that I followed and notice it goes from a 5/8" rubber hose to a smaller diameter more plastic hose all the way to some sort of box the size of the catalytic convertor.
It has a plastic sheathing cover to it so i coulod not locate a tear in the hose. Called Autozone and was told they only carry "rubber" hose and not aware of a plastic smaller diameter hose. |
Ok,
Have codes rechecked for any new codes then clear them.
Here are the Vacuum Diagrams one for California Emissions and the other of course for all others...
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
