Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1997 Nissan Maxima Air C...
Auto Repair2004 Dodge Caravan Hesit...
Auto Repair1998 Nissan Maxima All K...
Auto Repair2001 Nissan Maxima Front...
Auto Repair1992 Nissan Maxima Timin...
Auto Repair1998 Nissan Maxima My Ca...
Auto Repair1996 Dodge Ram Valve Tra...
Auto Repair1991 Bmw 320 Front Brakes
Auto Repair1998 Nissan Maxima Car S...
Auto Repair1997 Dodge Avenger Timin...
Auto Repair1997 Nissan Maxima Oil P...
Auto Repair2005 Nissan Maxima Won't...
Auto Repair1995 Nissan Maxima Hard ...
Auto Repair1996 Nissan Maxima
Auto Repair2001 Nissan Maxima Car S...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Dodge Caravan Engine Cooling Fans Not Working
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue May 13, 2008 2:17 pm
By alydar66, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic 102000 miles
Hi, I have a 1998 Caravan and the engine cooling fans wont go on. Ive replaced the relay and the temp sensor. I have checked the temp sensor with a ohm meter to make sure the resistance changes when the engine warms up, and it does. Th sensor is working fine. When I pull the connector off the temp sensor the fans go on so I know the fans and fuses are fine. For some reason it seems the computer module isnt sending a signal to the relay to turn the fan on. I get the trouble codes P1491(radiator fan relay circuit fault) and P0118(engine coolant temp circuit high input). I am also having a problem with the air conditioning not working. When I do the self diagnostic test on the A/C the results are that it fails the cool-down test.
Does you have any ideas why the computer module isnt sending a signal to the relay? Could the A/C problem be causing the cooling fans not to come on? Could there be a problem with the computer module?
Find a repair manual for your Dodge Caravan Repair Question.
By Advertisment,
Posted at Wed May 14, 2008 5:05 pm
By mastertechtim, Tech level 9
Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5 (246) Give Feedback | Votes: 16
the 1491 is usually caused by a bad fan relay and or a blown fuse feed to the relay. if ok possible bad computer
Posted at Wed May 14, 2008 7:07 pm
Im not getting the 1491 code anymore that went away when I replaced the relay. But I still get code P0118(engine coolant temp circuit high input) and the fans still dont go on. The sensor seems to be working because I tested it in a pot off boiling water and measured the resistance while it was still on the car. For some reason the PMC wont tell the fans to go on.
Posted at Thu May 15, 2008 7:24 am
now we need to install a scan tool and watch the temp at the computer
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
