Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Lincoln Ls Valve C...
Auto Repair2008 Jeep Cherokee Star...
Auto Repair1992 Chevy Truck Over P...
Auto Repair1999 Hyundai Accent Bel...
Auto Repair1996 Audi A4 96 A4 No H...
Auto Repair2002 Pontiac Grand Am C...
Auto Repair1998 Ford Taurus Thermo...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Dodge Caravan clunking noise
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 06, 2008 11:53 am
By reojeff, Likes cars!
Give Feedback | Votes: 0
Suspension problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic 120k miles
I replaced broken front hub / bearings. Replaced caliper and rotors at same time. Immediately got a new loud clunking noise when turning especially at idle driving speed.
I replaced the half-shafts, since I had been pudhing on them while working on the hubs and the sway bar bushings (witness marks showed wear).
Tie rod ends seem tight, sway bar end links seem tight(grabbing and pulling on them.) have had the ball joints apart and they seem ok.
I'm puzzled at how the sound showed up right when I replaced the bearing / hubs. I followed the book procedure for torquing the axle nuts. It said 180lbs. My wrench only goes to 150lbs, so I guessed and it has to be really close.
I've pulled on the upper strut shaft and it seems tight, how can I test the bearing at the top of the strut? And does it make sense for it to start clunking just from replacing the wheel bearing. This noise showed up before I ever had the ball joint opened.
I even tried adding spacer washers between the rims and the rotors trying to rule out some difference or slack in the hub or rotor.
Help!! I'm running out of hair to pull.
Thanks in advance,
Jeff
Find a car repair manual for your Dodge Caravan Repair Question.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
