1998 Chevy Venture Engine runs great cold when warmed up di
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1998 Chevy Venture 6 cyl Front Wheel Drive Automatic 190000 miles
Greetings; my 1998 venture runs good cold but as soon as it warms up it begins to shake goes rich and shuts off. It now has a check engine light. Dealer said they had to replace o2 sensors a $400.00 car still does the same thing. Dealer has had the vehicle now for 4 weeks and can not seem to find out what is wrong. Any suggestion please?
By the way fuel pump, wiring harness, many sensors have been replaced. This has been acting up for sometime but now has really gotton bad.
well the best thing to do right now is go to autozone and have your computer scanned for free. then bring the codes back to us and we'll figure out what you need to do
Greetings and thank you for the advive. Closest auto zone is several hours away. Car is not drivable the way it is. The Problem is trying to isolate the problem. Codes that are being sent out of computer are not the problem accorind to the tech that worked on it. He told me they do not have a clue as to what is going on. Tech has replaced several other sensors that computer said was bad no help. Please do you have any other ideas?????? Nathan
the tech that worked on it could be wrong, or just trying to make some money for the shop or himself, this is why it is important to scan the codes, he could be telling you anything,, also if you cant do that , then you will have to start from the basics, fuel pressure regulator, engine coolant temp sensor,plugs ,wires,throttle position sensor
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
