Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1998 Chevy Venture 6 cyl Two Wheel Drive Automatic 120000 miles
abs light is on. brake light is on. there is no hydraulic pressure going to the rear drum brakes. the front disc brakes are fine. tried bleeding the system but could not get any thing to the rear. please help
You need to find out what codes are present. There will be some abs codes and the will likely lead to the solution of both symptoms. The ABS unit may need to be bled by use of a hand held diagnostic computer.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
