Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Chevy Tahoe RADIATOR
Posted at Sat Nov 07, 2009 12:26 pm |
By
bluetahoe,
New to the forum |
Give Feedback | Votes: 0 |
Engine Cooling problem
1998 Chevy Tahoe V8 Two Wheel Drive Automatic 147K miles
I JUST REPLACED MY RADIATIOR, WATER PUMP AND HOSES, BUT BROWN STUFF IF STILL RUNNING OUT OF MY RADIATOR & ITS RUNNING HOT, ITS LOOK LIKE RUST. BUT I WAS TOLD THAT IT WAS FLUSHED WHEN THE RADIATOR WAS REPLACED.I ALSO PUT A STARTER ON BUT WHENEVER I LET THE TRUCK SIT FOR 2-3 DAYS, IT WONT CRANK. IT WAS PLACED ON A MACHINE & I WAS TOLD THAT THE ALTERNATOR WAS GOOD. GO FIGURE.... |
Find a
car repair manual for your Chevy Tahoe Repair Question.
Posted at Sat Nov 07, 2009 6:15 pm |
By
pear69,
Moderator |
(34) Give Feedback | Votes: 11 |
What was flushed when the radiator was replaced? Is it a brand new radiator? |
Find a
Posted at Sun Nov 08, 2009 2:48 pm |
By
bluetahoe,
New to the forum |
A NEW RADIATOR WAS INSTALLED & IT WAS FLUSHED WITH THE RECOMMENDED ANITFREEZE FOR MY TRUCK |
Find a
Posted at Sun Nov 08, 2009 9:29 pm |
By
pear69,
Moderator |
The antifreeze speced for your truck is called Dexcool. It is orangeish/pink in color. The engine block will hold up to a gallon of coolant/water in it - even when you remove the water pump. You did not mention whether or not the block has been flushed-- so I assume it was not. The mixture of old coolant (which is probably rusty in color) and the orangeish/pink Dexcool is probably why the coolant is rusty in color...You can test the coolant. There is a tool you can buy at any auto supply store to test coolant.
Test the coolant. If it passes, the rusty color is probably not a problem. If it does not pass, then the entire cooling system should be totally drained. Removing the soft plugs in the engine block is the only way to totally drain the cooling system. Flush the system after new soft plugs are installed and refill.
Why did you replace the starter? Was it bad? Did you test the starter? By not cranking do you mean turning over or not turning over at all (like a dead battery)? Why was the alternater tested? |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
