Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1997 Ford Ranger 3rd Bra...
Auto Repair1999 Ford Explorer Anoyi...
Auto Repair1992 Pontiac Bonneville ...
Auto Repair1996 Mercury Sable Engin...
Auto Repair1995 Lincoln Continental ...
Auto Repair2000 Dodge Stratus Wont ...
Auto Repair1996 Hyundai Accent Obd ...
Auto Repair2004 Dodge Stratus Cylin...
Auto Repair1991 Ford F150 Kicking S...
Auto Repair1997 Mitsubishi Galant T...
Auto Repair1994 Gmc S15
Auto Repair1992 Chevy Camaro Check ...
Auto Repair1998 Chrysler Sebring Ac...
Auto Repair1997 Volkswagen Passat M...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Chevy Tahoe coolant in oil
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 09, 2008 7:11 am
By Jule Johnson, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1998 Chevy Tahoe V8 Four Wheel Drive Automatic 116385 miles
At 115541 miles oil/filter was changed. Shortly there after (116330) mechanic said intake manifold gasket needs replacement due to loss of coolant and small visable external leak. Gasket was changed, oil was not. Mechanic said it didn't look like coolant was in oil. He did not drain and replace oil/filter. Fifty miles later (116385) engine seized. Upon teardown sludge was evident in oil. The coolant was Dex-cool, less than one year old. I feel the oil should have been automatically changed because of the possibility of contamination. Mechanic said he looked at the dip stick and did not notice any coolant in the oil, an assumption that cost me more than $4000.
Your opinion would be appreciated.
Find a repair manual for your Chevy Tahoe Repair Question.
By Advertisment,
Posted at Tue May 20, 2008 4:32 am
By pear69, Have Donated
Reputation: 49.8Reputation: 49.8 (50) Give Feedback | Votes: 3
Just checking the dipstick for oil is not acceptable in my opinion. Yes the oil should have been changed, but the amount of coolant that could potentially get into the engine after this repair is not enough to seize it after 50 miles. My guess is that the intake manifold gaskets were installed incorrectly. There is a strict torqueing proceedure that must be followed to a tee. If not, the gasket can very easily crack -- internally, without notice -- and allow large amounts of coolant to flow into the oil when the engine gets up to temperature. Sounds like this happened to you. There is no doubt that the mechanic is responsible for this. He or she overtightened the lower intake manifold causing the gasket to crack and fail. I would contact a lawyer asap!
Posted at Tue May 20, 2008 5:11 am
By rhall77, Tech level 6
Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3 (92) Give Feedback | Votes: 3
i dont think that was the case because now days alot of intake gaskets habe metal spacers (at least GM does) to prevent over torqueing. I would say for sure not having the oil changed was the reason the engine failed. Anytime an engine has something takin apart that exposes the internal parts, an oil change in my opinion should be done.
Posted at Tue May 20, 2008 11:56 am
Well rhall77, thats if you use GM parts. The fel-pro (cheaper) lower intake gasket does not have the metal spacer update and is commonly sold at any autoparts store. Even with this spacer it most certainly is possible to crack this gasket upon installation. Consider this -- what if the lower intake manifold was warped? Was it checked for warpage? This is an all too common - over looked - problem. Also, in my opinion, even if the oil WAS changed - after replacing the gasket - the gasket was cracked. When the engine got up to temperature "50 miles down the road", this crack opened up and dex-cool destroyed this engine.
rhall77, I am sure you have changed many of these gaskets ( as I am sure the so called mechanic in this case has). If not then here is a little tip -- the first thing you do is drain the coolant. The little bit of coolant that still may be left inside of the intake WILL NOT cause a Chevy 350 cubic inch engine to SIEZE UP just 50 miles down the road. I am willing to bet if you poured 1/2 of a gallon of 50/50 dex-cool directly into the crank case of a chevy 350 there would be no problem. The problem here was the constant flow and mixing of coolant in the oil !!!
Posted at Tue May 20, 2008 12:12 pm
trust me i have worked in a dealer for many years. i have seen where people have not changed the oil but did drain the cooling system and the engine did fail. Usually a intake if it was warped (never seen one but may be possible) would also leak externally. I think and you maybe be right also for a constant flow, that it could be the gaskets (i never use after market gaskets), but it could also be corrision not sealing on the water ports. but i think in this case the oil not being changed did cause the problem. any contaimination of antifreeze in an engine (even the slightest amount) will destroy bearings in no time. TRUST ME. either which way we both look at it we are gonna have our own opinions. But at least we both know that antifreeze contamination was the main problem and yes contact your lawyer ASAP.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
