Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Isuzu Rodeo Questio...
Auto Repair2007 Jeep Wrangler Stee...
Auto Repair2000 Pontiac Grand Am
Auto Repair1988 Toyota Supra Engin...
Auto Repair1993 Cadillac El Dorado ...
Auto Repair1992 Toyota Tercel 1992...
Auto Repair1997 Ford F150 Rotor Be...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Chevy Monte Carlo fuel issues
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 12, 2008 1:02 pm
By truckinnut, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1998 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic 130000 miles
first my car wouldnt hardly start then when it did it ran rough for a few minutes but would clear up and drive as long as you wanted until you turned it off then it wouldnt start for awhile but woyuld do same thing i had run it out of gas so someone told me change filter i did now it starts right up and idles fine but when i gas on it it misses and if i try to drive it it wont hardly pull itsself i checked under the hood where you canpush the button to see the fuel spray before i chenged filter it would spray a good strem then spurt and repeat itsself now it spays a steady strem but its a weak stream can you please help
Find a car repair manual for your Chevy Monte Carlo Repair Question.
Posted at Sat Jul 12, 2008 4:42 pm
By mastertechtim, Moderator
Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3Reputation: 299.3 (299) Give Feedback | Votes: 20
you really need to connect a fuel pressure gauge and read the pressure. should be atleast 35 psi. also check the fuel pressure regulator on the fuel rail, it has a vacuum line connected to it, if you disconnect the vacuum line and there is any sign of fuel then thats your problem. get back to us if you need further assistance
Posted at Sat Jul 12, 2008 5:07 pm
i am worried it doesnt do anything like it did before it totally chenged before if you let it sit there and idle it woud clear totally up and had trouble starting now it fires right up but it sounds like its ticking and it idles fine but when you gas on it it tries to die and it backfires under the hood we checked the vacuum hose on the fuel rail no sign of gas
Posted at Sat Jul 12, 2008 5:15 pm
sounds like low fuel pressure. try disconnecting plug wires, one at a time on the coil tower and see if any are burnt or rusty.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
