Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Chevy Malibu gear shift stuck in park
Posted at Tue Nov 03, 2009 11:47 am |
By
gadgetmom,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1998 Chevy Malibu 6 cyl Front Wheel Drive Automatic 128000 miles
My 1998 Chevy Malibu gets stuck in park whenever the outside temperature dips below 60*F. The button that needs to be pushed in on the console stick in order to put the car in drive won't budge until the car warms up for about 20 minutes or more...a real waste of gasoline! As I stated earlier, this only happens when the temperature drops below 60*F...during the warm summer months it works just fine. My biggest concern is the safety hazard it causes my kids when they use the car to go to work and they have to sit in the car late at night waiting for it to warm up before they can drive home. I'm really hoping this is something I can take care of myself...I have spent w-a-y too much money on repairs to this car already!! Any help would be greatly appreciated. |
Find a
car repair manual for your Chevy Malibu Repair Question.
Posted at Wed Nov 04, 2009 4:28 am |
By
BMRFIXIT,
Certified 2CarPros Master Technician |
                (8550) Give Feedback | Votes: 85 |
The shift lock control feature was intended to prevent drivers from shifting out of Park with the vehicle running without the brakes applied.
However, if the ignition switch is in the Accessory (ACC) position, it may be possible on some vehicles to move the shift lever out of Park WITHOUT first activating the brake.
The shift lock control system is ONLY active when the ignition switch is in the RUN or ON position.
This means that when the ignition switch is in the RUN or ON position, the shift lever cannot be moved out of the Park position without activating the brake
(in case you have to take off in a quick you can start the engine in N and take off just dont put it back in park ),
check if you have brake light on when stepped on brake paddle if not check and replace brake light switch |
Find a
Posted at Wed Nov 04, 2009 6:13 pm |
By
gadgetmom,
Have Donated |
Thank you so much!!! Your suggestion worked and I can't tell you how relieved every member of my family is over this. We have been stumped by this for a long time and have tried a lot of other things and were sure that we would ultimately have to spend hundreds of dollars making yet another repair to this poorly engineered massive disappointment of a car. |
Find a
Posted at Sun Nov 22, 2009 6:41 am |
By
BMRFIXIT,
Glade all worked for you
thank you |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
