Engine Performance problem
1998 Chevy Cheyenne V8 Two Wheel Drive Automatic 152000 miles
I have recently relpaced all ignition wires, plugs, fuel filter.Cleaned throttle body and componets. I still have problem with starting.If it has warmed up, it will crank 1 st try.If it sits overnight ,It takes 7-10 times to crank it. I hear the fuel pump working after each try. After it has started and warm up it still falls nearly flat on its face under a load but eventualy gets going. any words of wisdom for me? Thanks Jamie
