Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Buick Century Cock...
Auto Repair2003 Ford Taurus Brake ...
Auto Repair1998 Dodge Neon Will No...
Auto Repair1998 Subaru Legacy Ther...
Auto Repair2003 Cadillac Escalade ...
Auto Repair1998 Buick Lesabre
Auto Repair2004 Chevy Impala Tempe...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1998 Cadillac El Dorado compressor will not come on
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Tue Sep 23, 2008 10:42 am
By rcssr, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
1998 Cadillac El Dorado V8 Front Wheel Drive Automatic 101000 miles
System stopped working, compressor will not come on. Dashboard signals "check A/C system" and "low refigerant pressure, A/C off" alternately. Mechanic evacuated and recharged the system with no change. He then jumped out the A/C relay in the fuse box under the hood and the compressor came on. System then worked flawlessly and was 45 degrees at the interior vents. Everything works fine with the jumper wire. Prior to recharge the inline filter (plastic) was replaced (there was no debris on it). New A/C relay did not correct the problem. I bought a climate control assembly for the dashboard and replaced the blower motor on the firewall, I even bought a new computer and nothing will make the compressor come on, but obviously the sytem is able to work fine. Tried to jump out the two sensors on the high side pipe that runs accross the firewall L to R. Nothing will make the compressor come on (other than jumping out the relay) or the allerts go away on the dash. Disconnected the battery at every repair attempt. The heater, the defroster (without the compressor coming on) and the blower all work fine. When you press the A/C button on the climate control, the system comes on but blows warm air. One of the mechanics I spoke to said the 'fan controller module' is bad but I don't know where that is or if it could be the culprit. My mecaninc (and I) have given up. HELP
Find a car repair manual for your Cadillac El Dorado Repair Question.
Posted at Wed Sep 24, 2008 5:05 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5Reputation: 682.5 (682) Give Feedback | Votes: 80
Is it still saying "a/c low" or any other a/c warning on the driver info center? Caddy's wont let the compressor come on til the codes have been cleared through the on-board system.To enter self diagnostics
Key on, press "warmer" and "off" at the same time,hold down until info center changes to diagnostic. Then press fan low until "ACM" is displayed.Then fan high until "ACM codes" is displayed.Then fan low until "clear ACM codes" is displayed. Then fan high to clear the codes "ACM codes cleared " will display. Turn key off.
Posted at Wed Sep 24, 2008 9:38 am
I followed your instructions to clear the ACM codes but the compressor will still not come on. I am still getting the messages "low refrigerant A/C off" and "Service A/C system". What now?
Posted at Wed Sep 24, 2008 10:13 am
Then the problem isnt fixed.......... sounds like the pressure sensor (located in the high side line) is bad if the system is full. If there are any error codes, the car wont let the comp turn on
Posted at Wed Sep 24, 2008 1:35 pm
There are two sensors on the high side (small tubing) and one big one on the low side (one inch + diameter tubing). Which one of the two would it be? one is near the dryer and one is on the drivers side. Can I replace it without loosing the freon and/or can I jump it out to see if it is bad (I think I may have done that already??) If I understand you correctly, even after I find a problem and fix it I will have to reset all the error codes on the dash. Can I reset them all or just the ACM? I know this is a pain but I have been at this for weeks and as you can see at considerable expense.
Posted at Thu Sep 25, 2008 4:43 am
My software doesnt say which is which... what color are the wires to the two switch's and I will try looking them up in the wiring diagram
Posted at Thu Sep 25, 2008 9:52 am
The low side (large tube) sensor has a pink and a green wire. The high side sensors are black and grey on the passengers side of the tube and dark blue and black on the drivers side. Let me know which one and if I can jump it out before I replace it. Also can I replace it without loosing the Freon?
Thanks,
Posted at Fri Sep 26, 2008 4:54 am
Im showing a dark blue/dark green for the high side pressure switch.I wouldnt jump it. According to Mitchell you dont have to discharge the system, but honestly I would just to be safe
Posted at Thu Oct 02, 2008 7:09 am
I bought the new high pressure sensor from Cadillac but we still have problem. There are two sensors on the high pressure line that runs along the firewall from right to left. Parts dept at Cadillac says there is only one according to their diagram. I don't want to replace the wrong one (assuming that this is indeed the problem) and loose the Freon multiple times. The high pressure line starts at the passengers (right) side of the firewall and travels across to the drivers (left) side of the car and then turns down below the master cylinder and then turns forward toward the condensor and attaches to it. That line looks like 1/2 inch diameter (guess) aluminum tubing. The line coming out of the evaporator (enclosed in the fan box assy) is 3/4 inch diameter (guessing) and gets reduced to 1/2 inch at the coupling that joins it to the high pressure line. There is a sensor on that 3/4 inch line (right before the coupling) that has a black and a grey wire attached to it and when I jump out the relay to engage the compressor that line gets ice cold. It changes to extremely hot right at the coupling point where it is ruduced to the 1/2 iinch line. That 1/2 line gets untouchably hot all the way across the firewall. The second sensor with the blue and black (looks black to me and not green) is located on that 1/2 in line all the way over on the drivers side of the firewall. Which one do I replace? Is the proceedure after replacement to clear the codes on the diagnostic (all of them or just the ACM?) and then recharge the system, or the other way around. Thanks for your patience
Bob Smith
Posted at Thu Oct 02, 2008 7:32 am
Try using a voltmeter on the switch plugs when comp is running, one is s switch and the other is a senor so the switch will simply turn on and off with 12 volts while th eother will send a signal that is of varying voltage
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
