Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Cadillac Deville
Posted at Sun Jun 28, 2009 10:48 pm |
By
landemartin,
New 2Carpros Member |
Give Feedback | Votes: 0 |
Engine Performance problem
1998 Cadillac Deville V8 Front Wheel Drive Automatic 124800 miles
Engine idles at 650 to 700 without air. With air on, idle speed fluctuates between 625 and 900 rpm. This is too slow to keep compressor running efficiently. Cycles on and off every 3 seconds.
Does this indicate a defective idler control sensor/relay? |
| Find out more about your Cadillac Deville Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Sun Jun 28, 2009 11:10 pm |
By
gstacey,
Certified ASE Technician |
 (914) Give Feedback | Votes: 57 |
I would lean more towards an A/C concern, since it only happens with A/C compressor on. Possibly an under/over charge, or failing compressor. The fact that it does fine when the A/C is off leads me to think the IAC is fine. You have no stall, or high idle. It sounds like the load from the compressor is drawing it down. |
- Donate Here |
Posted at Mon Jun 29, 2009 7:06 am |
By
landemartin,
Thank you for your reply. I just had a new compressor installed 11 months ago. And I had the freon level and the compressor checked last week. The mechanics told me they thought I needed a cooling fan (one wasn't working) and a new thermostat, so they installed these components. It didn't fix the problem. |
- Donate Here |
Posted at Mon Jun 29, 2009 9:52 pm |
By
gstacey,
Does the system cycle normally when the engine speed is brought up? The fast cycle time usually indicates that the pressure is pulling down rapidly, either by undercharge or a restriction. Does it seem to cool adequately? If there was another fault that would cause the PCM to stop with compressor operation, it should have some ACM codes in the programmer, or stored fault codes in the PCM. |
- Donate Here |
Posted at Mon Jun 29, 2009 10:16 pm |
By
landemartin,
Yes, the system cycles normally when engine speed is brought up. The mechanic said the system is full of freon.
There is a Service Engine Soon light on, but I don't know what codes it is returning.
I took off the AIC controller this morning. The plunger had black soot and grease/grime all over it. I cleaned it off with a cloth and squirted a dab of WD-40 into it and replaced it. After reinstalling it, the engine seemed to run about 50 rpm faster than it did before. The compressor didn't cycle but once every minute or so after that; however, the outside temperature was considerably cooler today than the other days I've been testing it. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
