Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 Buick Century No hot air from heater
Posted at Fri Nov 20, 2009 3:51 am |
By
pking1110,
Likes to hang around! |
Give Feedback | Votes: 0 |
Heater problem
1998 Buick Century 6 cyl Two Wheel Drive Automatic 134200 miles
I am not getting any hot air out of my vents when the heater is turned on. The temp gauge starts to move to hot then I get a little heat and the Temp drops then no more heat? |
Find a
car repair manual for your Buick Century Repair Question.
Posted at Fri Nov 20, 2009 4:00 am |
By
Service Writer,
Certified 2CarPros Master Technician |
              (7328) Give Feedback | Votes: 98 |
Is the coolant full? Check it when cold. |
Find a
Posted at Fri Nov 20, 2009 12:00 pm |
By
pking1110,
It has some fluid in the resvior and a lot of crud on the cap. |
Find a
Posted at Sat Nov 21, 2009 12:33 am |
By
Service Writer,
Bring the engine to operating temperature and feel the heater hoses going into the firewall. IF one is warm and the other is cold, try backflushing the heater core. |
Find a
Posted at Tue Nov 24, 2009 4:17 pm |
By
Buickman98,
New to the forum |
my heater did that , i checked the coolant it was very low , so opon further inspection i found out my intake gasket was leaking and that is why my coolant was low ..so yada yada yada i got it fixed and my heat works fine and my engine did not explode so get it checked if your coolant keeps getting low
p.s this year and model are legendary for having faulty gaskets ..look around the engine for coolant in places that it shouldn't be |
Find a
Posted at Wed Nov 25, 2009 2:46 am |
By
Service Writer,
3.1 and 3.4 were both notorious for that. At 134,000 I'm surprised it wasn't already replaced.
Congrats. |
Find a
Posted at Fri Dec 04, 2009 6:02 am |
By
pking1110,
I flushed the cooling system and the leak as gottin worse. I can't afford to fix the gasket right now but I do believe that it is leaking. Thank you for the reponses. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
