Car Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1998 BMW Z3 High RPM misfire
Posted at Fri Nov 06, 2009 6:27 pm |
By
Jmai,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1998 BMW Z3 6 cyl Two Wheel Drive Manual 77,000 miles
2.8 L engine Misfire at approx 5800 RPM, sets CEL. Sometimes hear knocking after misfire.
Generic code reader does not read codes. Peake code reader (BMW specific) indicates misfire in various cyl, no pattern, but cyl 4 never has come up. No other codes detected.
Car runs and idles fine otherwise, even after code is reset. Plugs, coil connectors, fuel filter replaced. Coils OK. 1 can of Techtron put in tank. Fuel pressure OK, Mass Air Sensor, idle control valve, and DME (computer) OK. Air filter clean. No vacuum leaks detected.
Why only high RPM misfire? Also how is fuel volume checked? |
Find a
car repair manual for your BMW Z3 Repair Question.
Posted at Sat Nov 07, 2009 5:02 am |
By
mathiaso,
Certified 2CarPros Technician |
  (318) Give Feedback | Votes: 14 |
High RPM mean load.
it misfires erratically when it comes under load or accelerates. The engine is obviously misfiring under load but does not do it all the time. The most likely causes here would be a defective ignition coil, bad plug wires or worn out or fouled spark plugs.
I do not know what you mean by"coil ok". |
Find a
Posted at Sat Nov 07, 2009 7:45 am |
By
Jmai,
Have Donated |
Engine has individual coil packs above each spark plug Spark plugs replaced and properly torqued. Another set of coils was installed to eliminate a defective coil. Also new coil rubber boots were installed.
Could it be a crank sensor or cam sensor slowly starting to go? Would this affect all engine RPMs or only show up at high RPMs? Car starts, runs and idles fine after misfire code is reset.
Also my generic OBD II reader detects no codes, but a BMW specific one, Peake, detects the misfire code. |
Find a
Posted at Sat Nov 07, 2009 9:43 am |
By
mathiaso,
I would suspect the cam sensor.
it is the only one responsable for telling the computer wich cylinder is a top dead center and wich one is approching so the computer can energize the relay ,so the relay can energize the injector.
fuel volume test is good approach, it seem like the engine is starving.it start and runs rough.
Low fuel pressure creates a lean fuel condition that can cause lean misfire, hesitation, rough idle, hesitation and misfire on acceleration (high rpm)
Have the injectors cleaned, walmart is the cheapest place so far I know.plug injectors causing bad spray pattern can cause misfire.
check fuel pump wiring for moisture.check the fuel filter and lines for obstructions and the operation of the fuel pressure regulator before you condemn the pump.
On european EFI systems, the OEMs recommend using a static pressure test with the engine and ignition off. This is done by bypassing the fuel pump relay and energizing the pump directly
Static Fuel Pressure Test
With the key on, engine off (or with the fuel pump energized), fuel pressure should come up quickly and hold steady at a fixed value, one once per second. |
Find a
Posted at Thu Nov 12, 2009 6:40 pm |
By
Jmai,
Have Donated |
clogged catalytic converter
will need replacement |
Find a
By
Jmai,
Have Donated |
Find a
Posted at Thu Nov 12, 2009 8:44 pm |
By
Dr. Hagerty,
Certified 2CarPros Master Technician |
(80) Give Feedback | Votes: 20 |
Thanks for feeding that back to us. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
