Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Drive Train Axles Bearings problem
1998 BMW M3 6 cyl Two Wheel Drive Manual 82000 miles
I WAS WONDERING HOW YOU THINK THE LABOR IN HOURS IT IS TO REPLACE A REAR DRIVERSIDE AXLE IN A 1998 BMW M3 AND POSSIBLLY HOW MUCH IT WOULD COST FOR EACH HOUR THAT THE WORK IS DONE, AND IF YOU KNOW HOW MUCH THE AXLE WOULD COST AS WELL
are you asking for time to repair axle bearing or replace the half shaft? if the bearing has failed and requires replacement, then you have about 2.5 hours of labor plus the cost of the bearing, about 70 U.S. dollars. shop labor rates are variable and can range from 80 to 150 per hour depending on where you are.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
